2wd propshafts info reqd
Is a rwd t5 cosworth prop single piece or is it 2 piece with the donut ring?
I'm guessing the donut is to help in not breaking props with hard launches big power etc,?
Reason I ask is I'm building a t5 gearbox and cosworth powered car ATM, going for 400 horses...... Need to make propshaft custom size, would you 2piece it or single? it's gonna take hard abuse?
Another q, I've got the axle end flange, need the t5 end, was it only cosworths props that fitted these t5 boxes?
Cheers pics would help
T5 doesnt use a donut its the mt75 from the 4x4 that has the rubber donut
Theres pro's and cons with a single piece prop,
But most people find theres to much vibration from them and stick with a centre bearing
PAUL S
Jan 3, 2016 04:40 PM
cossie09
Nov 25, 2015 07:55 PM
cossie09
Nov 25, 2015 07:36 PM
