3 door cosworth solid rear beam bushes
Old Jan 24, 2016 | 02:18 PM
dal3door's Avatar
dal3door
Default 3 door cosworth solid rear beam bushes
hello need a bit of heip
just fitted my 6 degree ream beam on the car today with the solid mounts can any tell me if there is a rubber bushes that goes between the body and the beam i have a gap between the bush and the body just need to no if that right
thanks darren
Old Jan 24, 2016 | 03:49 PM
cozzy jeff's Avatar
cozzy jeff
no mate no bush required.
Old Jan 24, 2016 | 04:02 PM
ajamesc's Avatar
ajamesc
cossie fan (unluckerly)
Just fitted a set to my saff sure there's a small gap on that too. The centre pin up the middle of the bush makes contact with the chassis rail in its locating hole
Little_grant
Feb 10, 2016 02:46 PM
Matt Baxter
Jan 29, 2016 05:52 PM
Little_grant
Jan 29, 2016 05:15 PM
2wdsaph ben
Jan 28, 2016 01:24 PM
Jane Gray
Jan 24, 2016 07:04 AM
