Rs turbo speedo not working
Hi All
My rs turbo/s1 speedo has never worked
Iv checked the cable thats fine put a different set of clocks in still nothing
The car drivers fine and all gears work spot on dont slip nothing can drive it hard and still fine
Gearbox was rebuilt afew years ago with lsd etc the car hasn't gone anywhere
Anyone know what mite be up with it
Thanks
Thanks
Faulty speedo drive in the box, it is removable when you remove the roll pin. Also check the length of the inner cable, I've had the end 5 or 6 MM. Snap off in the past.
Ginger
Ginger
