Heater Not Working ST170
Old Jan 22, 2016 | 09:45 AM
Dean Rhodes's Avatar
Dean Rhodes
Default Heater Not Working ST170
This is a 03 plate ST170
Recently I've got no heat coming out of the blower. The air flow itself is fine, works at all speeds just not heat.
Checked water levels etc but I'm not an expert (obviously). Any pointers about how to fix?
Old Jan 22, 2016 | 11:31 AM
Pitbull69's Avatar
Pitbull69
Possible temp sensor, common for them to go wrong, I have also heard of fuses and resistors being at fault, buit not sure if that would apply if the air flow is working perfectly.
Old Jan 22, 2016 | 11:39 AM
STeve's Avatar
Super Moderator
if the heater speeds are working but no hot air could be a thermostat issue or worst still a matrix or if you have basic style twist knob to select heat a snapped cable connection on rear of it
Old Jan 22, 2016 | 12:56 PM
Dean Rhodes
Hi
I've just topped up the coolant and when I have been running the engine it is starting to get slightly warm now, however it is not giving out the heat you would normally expect.
Looks like the heater is working but below capacity. Do you thin there could be a blockage somewhere?
Old Jan 22, 2016 | 01:03 PM
STeve's Avatar
Super Moderator
the matrix is where the heater gets its heat but a dodgy thermostat will also cause poor circulation
Old Jan 22, 2016 | 01:22 PM
Pitbull69's Avatar
Pitbull69
Also when you topped it up did you make sure there wasnt any airlocks in the system, Also if you needed to top coolant up, means you might have a leak, Check your thermostat housing as they common to start leaking,
Tank Mike
Ford Focus ST
Apr 30, 2017 11:35 AM
p.laver
Ford Fiesta
Feb 24, 2016 07:34 PM
Ford Focus ST Parts for Sale
Jan 19, 2016 01:18 PM
Pitbull69
Jan 9, 2016 04:50 PM
DixieTheKid
Jan 7, 2016 07:28 AM
