Slipping clutch after brand new clutch fitted
Old Jan 21, 2016 | 02:44 PM
Little_grant's Avatar
Little_grant
Default Slipping clutch after brand new clutch fitted
Hi all really need to pick some brains
I've got pretty much stock rst s2
Ony as a chip ecu and t3 turbo with 360 roller bearing and a exhaust
I've just had a full stage 1 clutch kit fitted brand new quadrant and cable so all is new but the cluch still slipping
With lowest of boost at 7psi the flywheel looks to be in top condition too just wondering if anyone else as had this issue and have a idea on how to fix it many thanks
Old Jan 21, 2016 | 03:30 PM
Little_grant
Was fitted by my local mechanic which I believe to be pretty good done far few jobs for me as far as the clutch goes I did buy it off a ebay shop didn't say the make as such just that it was rated for 220 bhp at 7psi it's not running that
I didn't have the fly wheel skimmed could that be the issue my be
Old Jan 23, 2016 | 08:11 PM
jamie's's Avatar
jamie's
Either your flywheel has had it
Or its a techniclutch special,
You say its a stg 1 kit? Is the pressure plate red?
What was the name of the ebay company you bought itfrom
Old Jan 23, 2016 | 08:52 PM
mk3ste's Avatar
mk3ste
I'm of the same opinion pal
Old Jan 29, 2016 | 05:15 PM
Little_grant
Pressure plate is red yes mate but would like to update I've now driven about 200 miles and it seems the clutch needed to bed in its now holding 14psi with no slips thank god
But I am thinking of doing the Mk5 pedal change and putting a 3 padel clutch in
Gary @ RS CLASSICS
Jan 5, 2016 05:27 PM
ekjim
65
Jan 4, 2016 05:23 PM
Tim Wharton
Jan 2, 2016 08:39 AM
Ian e34 m5
Dec 26, 2015 09:24 AM
RIB1122
Dec 23, 2015 01:14 PM
