Ford Focus Range This Section Contains All The Ford Focus Model Specific Forums.
Immobiliser Light Problem Ford Focus MK 2
Old Jan 20, 2016 | 02:52 PM
melpear's Avatar
melpear
Default Immobiliser Light Problem Ford Focus MK 2
IMMOBILSER LIGHT PROBLEM ON 2010 (OLD SHAPE) FORD FOCUS TITANIUM (KEYLESS SYSTEM)
I have a Ford Focus Titanium & just before the Christmas period I noticed that the immobiliser light i.e. the one above the general warning light, occasionally flickers on & off, this is the light which flashes every few seconds when the ignition is switched off.
The above only occurs intermittently & I cannot find any particular pattern to this. I have had a word with my local independent garage, who have a range of computer diagnostics for my vehicle & at first they thought this would identify the problem but after having a word with a Ford expert they are not so sure.
I have changed the batteries in both key fobs & used the different fobs separately thus eliminating this as a cause of the problem.
I have been onto several Ford forums & it would seem that the cure for the above problem, which seems to occur on some Ford models, is somewhat hit and miss. There also seems to be a wide range of problems which could happen if the problem is not fixed, ranging from total shutdown of the car or to just living with the problem as I have already driven over 300 miles since I first noticed the it.
I wonder anyone could offer any advice?
Old Sep 8, 2017 | 04:18 PM
deathrider666's Avatar
deathrider666
Damn Cars
Did you have any luck solving this?
Mine is doing the same, 2010 Focus Titanium, light flashes on occasionally when driving, causes the stereo to hiccup for a split second but still drives fine.
41
Jul 1, 2016 04:21 PM
Ford Focus RS Parts for Sale.
Dec 3, 2015 09:09 AM
Ford Focus ST Parts for Sale
Dec 1, 2015 11:37 AM
tank1987
Nov 17, 2015 07:00 PM
