2wd Saph Cosworth standard breather system.
Jan 17, 2016 | 12:39 PM
I'm not the most mechanically gifted, so I apologise for that.
I've got a standard 2wd Saph Cosworth which is 90% complete. I'm looking to fit the standard breather system back into it and I have all the parts. However, in struggling to find where everything needs to go to connect it all.
Does anyone has some advice/instructions/images that can hopefully make the installation fool-safe?
I'll be grateful for any advice. Thanks.
Jan 17, 2016 | 12:52 PM
Below the inlet manifold you should have a kidney box?
From here a hose should connect back the the airbox.
Martin
Jan 17, 2016 | 12:58 PM
The kidney box hasn't been fitted yet, after a previous owner removed it.
I'm assuming the long pipe that goes to the airbox clips into the top of the kidney box?
I'm ok up to that point, but it gets messy (for me) with these pipes....
Jan 17, 2016 | 01:07 PM
Quote:
Originally Posted by
Braddaz1
That pushes into the kidney box then returns to the air box and one returns to plenum cover
Jan 17, 2016 | 01:13 PM
Jan 17, 2016 | 03:47 PM
Thanks for the replies. Now where do the 2 open ends of the pipe go?
Jan 17, 2016 | 04:15 PM
one goes to the one way valve on the inlet manifold and the other goes to airbox
Jan 17, 2016 | 04:31 PM
Jan 17, 2016 | 04:35 PM
Does the kidney box just tap into place?
Jan 17, 2016 | 04:59 PM
Jan 17, 2016 | 05:01 PM
Thanks everyone. It should be an easy thing to sort now.
Jan 17, 2016 | 05:02 PM
where abouts in Newcastle you from mate?
Jan 17, 2016 | 05:05 PM
Wallsend. Just over the water from you.
Jan 17, 2016 | 05:07 PM
are never mind lol. I try to avoid Wallsend if I can
do you have any pics of your car?
Jan 17, 2016 | 05:13 PM
Yeah, it's an acquired taste over here :lmao :
That's it at the moment.
Jan 17, 2016 | 05:24 PM
It won't look like this in a few weeks time. It's very dusty, but it's rust free underneath it all.
Jan 17, 2016 | 07:30 PM
cozzy jeff
Nowt wrong with Wallsend, had a few pints in the Queens Head
Jan 17, 2016 | 07:49 PM
You're braver than me Mike
Jan 17, 2016 | 07:55 PM
saphcosmike
Mike my ex hoddie used to run the Queens,small world
Braddaz1
and me lol.
Jan 17, 2016 | 08:13 PM
Are you guys in the Tyne & Wear RSOC then?
Jan 17, 2016 | 08:19 PM
Jan 17, 2016 | 08:40 PM
Can any of you local guys recommend somewhere nearby to go to get bits and pieces coated? At some point my cam cover will need re-done.
Jan 17, 2016 | 08:46 PM
your in luck,I've getting all my stuff done at betta blast in new York,ask for Billy great guy tell him I sent you over.
Jan 17, 2016 | 08:49 PM
That would have been my first port of call. I'll be sure to mention you and I'm reassured that they're the place to go to locally.
Jan 17, 2016 | 08:52 PM
I've been going there for years and wouldn't go anywhere else,I'm sure he won't let you down.
how far you going with the car,are doing the beam ect?
Jan 17, 2016 | 08:58 PM
It all depends on how my finances are to be honest. It's a 2wd, but it has the 4x4 bonnet, rear light clusters and it has been de-locked.
Ideally, I'd like to restore everything back to 2wd spec. I'll just get the cam cover done early on once the car is up and running, and I'll see after that as to what else I can get coated.
Escortdriver1
Jan 8, 2016 03:51 PM
IainRS1700T
Jan 1, 2016 10:14 PM
cossie330
Dec 22, 2015 07:57 PM
IainRS1700T
Dec 21, 2015 11:16 AM
Tim Wharton
Music & Car Audio Chat
Dec 20, 2015 02:40 PM
