L8 ecru and throttle position sensor
Any particolar type? Some had different chassis within the same run of L8's, Pectel board expansion needed? Is thechip inside the ecu needed and For what car? CAT or non Cat version, green lable 4x4 Cosworth version or the red lable non Cat. version?
Now For the tps, red or Black? PF09 or PF01? or even the red PF10 version that turns anticlockwise!
Don't want to come over as a know-it-all ass but as you can see, there are quote a few versions available..
I've Got a few Left over mate, let me Know Your exact recquirements and i'll try and sort it.
Cheers-Andrew.
Cheers-Andrew.
Hi I have a Sierra sapphire L6 ecru in my transit van with cosworth engine in and a word with Stu at Motorsport developments said to upgrade I need a L8 ecu and tps for same then he can map / chip it. So that's the information I have you could ring him and just say it's for the guy with the cosworth mk3 transit I have had it at his place then I would buy whatever he said I needed.
E9GY
Jan 3, 2016 08:57 PM
