Fiesta rs turbo start hunting when temperature is about 85
Old Dec 27, 2015 | 02:13 PM
kevin micallef's Avatar
kevin micallef
Default Fiesta rs turbo start hunting when temperature is about 85
Hi can someone tell me why the car start hunting when the temperature reach 82 decrease and come rich on fuel and than it start to stalls at times as well the idle sensor I might not using it because a use a DTA ecu I use only air temp sensor, tps sensor, coolant temp sensor, and the map sensor. Thanks hope you can help me
paceo
Jan 5, 2016 06:59 PM
kevin micallef
Dec 27, 2015 12:55 PM
STAFFY OWNER
Dec 27, 2015 12:31 PM
RIB1122
Dec 23, 2015 01:14 PM
muffster
Dec 18, 2015 06:13 PM
