25 mm lowering
Old Dec 10, 2015 | 06:52 PM
A.t.p's Avatar
A.t.p
Default 25 mm lowering
Hey everyone!
I'm about to lower my Rst, BUT..
I'm from Denmark and with 40 mm lowering, my rst can't pass the MOT.. So i Would have to raise it again every second year.. But if i get 25mm lowering it Will just do.
So, i can't decide if i should go with the legal 25mm or if it's to High for my taste :/ i've got 16" azev A's on the car..
I Would love to se alot of pics of the rst with 25mm lowering, hopefully making it easier to decide
Old Dec 11, 2015 | 04:28 PM
perry s2 turbo's Avatar
perry s2 turbo
Here's mine on 25mm mate
Chopshop85's Avatar
Chopshop85
25mm is a nice compromise I think. I've had this car lowered 60mm & 40mm and it's much nicer to drive at 25mm.
This is on 16's with a 205/40 profile tyre.
Old Dec 11, 2015 | 04:52 PM
A.t.p's Avatar
A.t.p
Originally Posted by A.t.p
Hey everyone!
I'm from Denmark and with 40 mm lowering, my rst can't pass the MOT.. So i Would have to rise it again every second year.. But if i get 25mm lowering it Will just do.
Thank you, both of you! It actually looks great! And beautifull cars
As you Can see, my rst is a bit high
Would love to see more
Old Dec 11, 2015 | 05:03 PM
Rob_DOHC's Avatar
Rob_DOHC
Sorry for the blury phone pic, this was a little over 30mm from standard and I hated it, I don't think rst's look good too low. In the end I went for -20mm rear and event the front out on the coil overs, better in every way than the -30 was so I can imagine -40 would be a bit horrid to drive.
Yours looks higher than standard though?
Rob,
Old Dec 11, 2015 | 06:22 PM
Chopshop85's Avatar
Chopshop85
It does look higher than standard.
Are the base model mk4 shocks and springs different, or is it just the springs.
IIRC RST's sit 20-25mm lower than other mk4's?!?
Old Dec 17, 2015 | 07:54 PM
makaveli96's Avatar
makaveli96
A.t.p your rs looks nice with the limited edition spoilers on the bumpers and the azev's, could do with lowering a bit more.
64
Jan 23, 2016 05:15 PM
CossieRich
39
Dec 24, 2015 08:34 AM
turbochild
78
Nov 30, 2015 03:12 PM
Hellraiser
12
Nov 15, 2015 03:42 PM
shark91
Nov 12, 2015 04:38 AM
