Got a 4 pot front cosworth brake conversion for sale that I removed from my series 2. The calipers have had the correct 4mm machined off so all you need to do is drill out and tap your hubs. All bolts included. The discs are as new they have done 300 miles max as have the pads (283mm). Included is a set of braided hoses that I had to have made for this conversion. Everything to just bolt on and bleed up and away you go. The calipers had all new seals fitted when I got them from big red.
Looking for 160 collected from barnsley/Sheffield area.
Reason: sold
Would you post these mate? Just what I'm after but miles from you?
I can package them up for you if you want to sort your own courier buddy as I really don't get time to do anything these days, work is just stupid busy
