Cosworth 4x4 rear brakes onto XR4x4
Old Dec 4, 2015 | 08:03 PM
JFB Tech's Avatar
JFB Tech
Not entirely sane
Default Cosworth 4x4 rear brakes onto XR4x4
Does anyone know if you can fit Cosworth 4x4 calipers and hangars for the vented discs straight onto the hub carriers of a 92 XR4x4 or does it need the hub carriers as well?
Old Dec 5, 2015 | 04:45 AM
cossie09's Avatar
cossie09
Hi .you will need the 4x4 cosworth rear hubs as well been there done that.
Hope this helps
Old Dec 5, 2015 | 08:31 AM
costina's Avatar
costina
Live long and prosper!!
As above cossie hubs will be required as this denotes disc size.
xr is 257mm
cos is 273mm
for a cheaper option you could fab up some brackets to move calipers up and rotate carrier towards the front of the car to clear mountings.
Paul
Rs Gus
41
Jan 26, 2016 05:07 AM
-=Cossie=-
Dec 4, 2015 06:12 PM
M K
Dec 4, 2015 02:32 PM
Tinshaw
Nov 28, 2015 10:38 PM
Tinshaw
Ford Escort RS Cosworth
Nov 28, 2015 06:18 PM
