Cheap way to fit 4x4 plenum to 2wd inlet manifold
Old Dec 4, 2015 | 06:12 PM
-=Cossie=-'s Avatar
-=Cossie=-
Default Cheap way to fit 4x4 plenum to 2wd inlet manifold
Hi, i have a 2wd cosworth and wanted to fit the 4x4 plenum and a 14mm spacer without the hassle of changing the fuel rail to the 4x4 one or moving the bracket so it fits in line with the 2wd fuel rail, so this is what i did, if you don't have a spacer you can put it the other side of the bracket instead.
the tubing is from b&q at just under £8 its 15 x 15 mm, so i got some larger bolts and cut a piece off as a spacer to sit where the bracket should be, the wiring loom hides it perfectly and it works great.
Luke_ZS
Nov 23, 2015 04:47 PM
truffleshuffle
Nov 13, 2015 11:19 PM
cossirob
Nov 6, 2015 09:35 AM
