Steering column brace bar.
Old Dec 2, 2015 | 12:08 PM
Chopshop85's Avatar
Chopshop85
Default Steering column brace bar.
Picked up one of these ages ago and while the dash is out I thought I would fit it. However I've no idea where it goes?
Does anyone have any pictures of one fitted?
Old Dec 2, 2015 | 02:04 PM
Roscopeco's Avatar
Roscopeco
P8 Managed S1 with ALS
Not sure which one you have but mine bolted to main column stud and other end went to drivers side kick panel . Drill a hole and bolt it in
Old Dec 2, 2015 | 04:22 PM
Chopshop85's Avatar
Chopshop85
Its got a 90 degree angle one end, and a fork the other.
I assume you mean the stud on the underside of the column? (as opposed to the ones behind the steering wheel)
Old Dec 2, 2015 | 07:20 PM
Roscopeco's Avatar
Roscopeco
Fork end to under the column where it mounts to the bulkhead . Hole end to kick panel
dickdastardley
Ford Escort RS Cosworth
Feb 5, 2016 11:42 AM
cossie09
Dec 9, 2015 03:23 PM
fordsteve77
Escort Range
Nov 27, 2015 11:27 AM
cossie09
Nov 25, 2015 08:27 PM
cossie09
Nov 25, 2015 07:55 PM
