cosworth gasket set
Old Nov 18, 2015 | 10:41 AM
CosworthGuy's Avatar
CosworthGuy
3dr Cosworth owner
Default cosworth gasket set
So. My 3 door has been languishing in the garage about 3 years as the head gasket started failing. I've already purchased a small turbo escos gasket and 3 door head bolts from Matt Lewis for the job. Now I'm thinking while the engine is out and in the bench I'd be a fool not to renew all the other associated gaskets and seals. The question is which ones. I look online and ebay. I see cometic this, Viton that. Now I've seen a set that has a steel centre and foam either side. Claiming to be superior. It's a minefield. Help lol
Old Nov 18, 2015 | 10:58 AM
cozzy jeff's Avatar
cozzy jeff
cometic gasket set will be fine,and re-usable.
Old Nov 18, 2015 | 08:40 PM
Jules44's Avatar
Jules44
10 Year Member
Re-usable as in head gasket?
Old Nov 18, 2015 | 10:18 PM
Dezzer's Avatar
Dezzer
4x4 resto
Its the other gaskets that are supposed to reusable , not advisable to re-use a headgasket
Old Nov 18, 2015 | 10:19 PM
botters's Avatar
botters
competant bodger
i used the steel cored gaskets on my old 3 door they worked bang on did not lose a drop of any fluids all the years i had it
Old Nov 20, 2015 | 12:58 PM
CosworthGuy
3dr Cosworth owner
These ones http://www.ebay.co.uk/itm/HIGH-PERFO...6_r663VBIcqRgA
simontrayler
Mar 22, 2016 09:45 PM
euro_peon
Escort Range
Oct 24, 2015 06:23 PM
Danster76
Fiesta RS1800/RS Turbo
Oct 24, 2015 02:12 PM
Slimm91
Oct 23, 2015 08:52 PM
J40davies
Oct 21, 2015 12:43 PM
