Castor angle
Old Nov 17, 2015 | 01:44 PM
mark r's Avatar
mark r
Default Castor angle
afternoon people
I'm after some advice,i fitted 4x4 hubs to my 3dr si I can fit new gas gold and some ap brakes.
But now my castor angle is way out
Do I have to fit 4x4 arb to bring castor angle back ??
Any help would be grateful
Thanks mark
Old Nov 17, 2015 | 02:52 PM
Marc sierra's Avatar
Marc sierra
Are the 4x4 hubs the only part from the 4x4 that you used? And which way is the castor angle out, too high or too low?
The 4x4's have different geometry hubs, arb and crossmember. So I wouldn't advise to mix and match any 2wd and 4x4 parts. Although with only the 4x4 hubs I thought it might have been OK, but apparently not.
Old Nov 17, 2015 | 08:53 PM
mark r's Avatar
mark r
Hi Marc , I've the 4x4 hubs , changed also half the adjustable bottom arms to pinch bolt type to match hubs.still using 3dr arb
Castor angle of wheel is forward
Now to get 3degree of camber I've nearly would out whole of steering rod/track rod from track rod end
What is the minimum amount of thread that could be safely left in track rod end
Thanks mark
Old Nov 17, 2015 | 09:10 PM
Marc sierra
I'm a bit confused. Earlier you were talking abou castor, now camber. But for both you don't use the track rod to adjust it. The track rod is only for adjusting the tracking. And are you really trying to set camber to -3 degrees??
Old Nov 17, 2015 | 09:53 PM
mark r's Avatar
mark r
Sorry to confuse you Marc
Yes I have a little to much forward castor but I think it's ok
Do you think -3degrees of camber is to much
Mark
Old Nov 18, 2015 | 07:23 AM
Ridgey's Avatar
Ridgey
3 deg camber is about as much as you'd want for track use, it's to much for road though (adj TCAs used for adjustment).
Castor, as much as you can get on cossie the better.
Old Nov 18, 2015 | 02:54 PM
Marc sierra
If you want to run 3 degrees of camber on track but the track rod ends are not long enough you can use track rod ends from a Granada mk3, which are the same fitment but about 1.2 cm longer than the Sierra ones. As far as I'm aware the Granada mk3 track rod ends are also the same as the Sierra XR4x4 ones (also wider track).
Too much castor would only be a problem if the tyres touch the bumper. Not enough castor is indeed a problem.
Old Nov 18, 2015 | 09:22 PM
mark r's Avatar
mark r
Ok next question , when I raise and lower car from floor with jack as wheels hit floor it's as if the weight on arb is changing toe angle on wheels
Mark
Old Nov 19, 2015 | 04:31 PM
Marc sierra
That could well be. The tca and track rod should run parallel, bu since you use a 2wd crossmember with 4x4 hubs it could be that the distance between the tca and track rod is different at the crossmember than at the hub, causing bump steer.
Old Nov 19, 2015 | 06:03 PM
mark r's Avatar
mark r
Hi Marco spoke with some helpful chap at scs and he told me I need to change to the 4x4 arb
So I gonna give that a go see how I get on hopefully sorts problem
Mark
Old Nov 19, 2015 | 09:06 PM
Marc sierra
A 4x4 arb will only push the wheels to the front further, increasing the castor even more and also make the wheels touch the front bumper. For the bumpsteer it won't help either.
Old Nov 20, 2015 | 08:34 PM
mark r's Avatar
mark r
Your right marco it indeed push
the front wheels even further forward and I tried getting mk3 granada track rod ends and there the same as Sierra so I've ordered tie rods 20 mm longer and gonna refit the 2wd arb
What a f........ Mission
All in a panic as I've a trackday next weekend
Mark
Old Nov 21, 2015 | 11:11 AM
Marc sierra
Still if you have bumpsteer it will be because of the 4x4 hubs and the 2wd crossmember.
Old Nov 22, 2015 | 02:18 PM
mark r's Avatar
mark r
The front suspension is so hard (500lb springs) that there's not gonna be hardly any suspension travel and it's only for track use so I think I be ok with bump steer there's only 1 way to find out
Mark
Old Nov 22, 2015 | 02:37 PM
MK MOTORSPORT's Avatar
MK MOTORSPORT
Mark
why are you running springs so hard ,have you not got roll bars
rog
14
Jul 4, 2016 03:28 PM
4x4RSMike
13
Dec 3, 2015 05:43 PM
Pomstu1637
Nov 17, 2015 04:45 PM
eddyj
Nov 17, 2015 04:27 PM
VEEDUBBED
Nov 15, 2015 05:39 PM
