Hesitating cosworth off-boost..........
Old Apr 5, 2005 | 08:26 PM
CosKev3's Avatar
CosKev3
Default Hesitating cosworth off-boost..........
Hesitates and holds back on light throttle/just after gear change etc
Is this just a low-comp/BD10 problem or should it drive as normal?????
Had injectors ultra sonically cleaned/re-conned over the winter,the base Co was 8% when I re-fitted them,set it to 3% and thats when its started this hesitating/holding back
Spec is:low-comp,BD10's,big valve ported/polished head,Stg3 MSD chip,
T34.63.
Thanks Kev
Old Apr 6, 2005 | 09:02 PM
CosKev3's Avatar
CosKev3
Old Apr 7, 2005 | 10:42 AM
Rs1's Avatar
Rs1
Which injectors are you using? Could be too much fuel,or too much fuel pressure or maybe even throttle position sensor. Or even coolant temp sensor. Its hard to say without actually looking at the car
Old Apr 7, 2005 | 08:23 PM
Toe Knee's Avatar
Toe Knee
had the same problem with mine, took it to powers 2day and they found out that when u rev'd the car the voltage droped to the fuel pump casuing fuel starvation. So have to replace the wireing for it. Could be the same thing, or just a sensor as said best to get it looked at really mate!!
Old Apr 8, 2005 | 06:53 AM
CosKev3's Avatar
CosKev3
Yeah will get it booked in
Runs fine on boost
Bit thirsty too,86 miles to £20
Fitted new water temp sensor couple months back,also if this was gone would'nt have been able to set Co at idle correctly.
Thanks
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Nov 5, 2015 08:12 PM
Nov 3, 2015 04:08 PM
Adam Graham
Sep 6, 2015 06:04 AM
wheelwizardrefurbs
Sep 5, 2015 10:52 AM
