Oil Cooling
Old Nov 9, 2015 | 04:08 PM
cpur's Avatar
cpur
Default Oil Cooling
I have an Escort Mk2 with a 360bhp yb on it, and was thinking of preparing it for track days, Does anybody know what size of oil cooler would suit a yb at that stage .
I was going for the largest found and then use an oilstat sandwich plate but due to limited space maybe i will look for something that is just a bit more than enough.
Thanks Guys
Warren
Old Feb 22, 2016 | 06:34 PM
MrEngineerdat's Avatar
MrEngineerdat
A few years ago i wanted oil cooling too, but really didnt want to go changing everything and spending loads of money.
So what did i do?
I found a rather heavy duty looking heat sink, not literally heavy, but could do a good job of sapping some heat away. It was about 5or6" square, with 2to3" tall fins standing off it, and i set about bolting it to the bottom of my sump, using computer heatsink compound that sets like cement to make the perfect join. The heatsink needed a little work on the flat face to make it fit my sump nice and snug, and the sump had a captive nut welded in place to take the underhanging heatsink. When it was bolted on some fuel tank sealant was used on the captive nut to stop it leaking. Jobs a good'n! It noticably took longer to warm up, and the fans almost never cut in. Its important i think, to have the veins of the heatsink lengthways with the car to accept the high speed air underneath and make a good heat exchange. Just... God help the cat if ever you run one over, it'll come out the other side like mince meat.
Old Feb 22, 2016 | 06:35 PM
MrEngineerdat
Default DIY oil cooler
So what did i do?
Old Feb 22, 2016 | 06:44 PM
MrEngineerdat
Be aware though, if your gonna do this, you mustnt take liberties with speed bumps. It wouldve been better im sure if i used 3 bolts to hold it on. I think it took a knock underneath with my spirited driving and started to leak a drip or two here and there. I reckon this could be a half decent race mod if its done professionally, cos it was noticable i tell ye, even on the standard pants temp guage.
lee2cossies
May 2, 2016 10:56 PM
Roosie
40
Dec 26, 2015 06:23 PM
Harris.
Nov 9, 2015 08:41 PM
Lawrence Hill
Nov 7, 2015 07:34 AM
Zammy
Nov 5, 2015 11:49 AM
