Custom Rs turbo inlet manifold
Old Nov 8, 2015 | 05:20 PM
jay030787's Avatar
jay030787
Default Custom Rs turbo inlet manifold
Does anyone no were or someone that can do custom inlet manifolds for my escort rs turbo wanting to be running 400bhp + and want to do away with the over engine charge pipe
Old Nov 8, 2015 | 06:53 PM
jonfoc's Avatar
jonfoc
Engine?
Old Nov 8, 2015 | 07:06 PM
jay030787's Avatar
jay030787
1.6cvh
Old Nov 8, 2015 | 07:16 PM
little bram's Avatar
little bram
Good going to get 400 out of cvh. Who's mapping the car?
Old Nov 8, 2015 | 07:23 PM
jay030787's Avatar
jay030787
I am mapping it and people are getting 450 out of them so should be fun
Old Nov 8, 2015 | 07:30 PM
little bram
Really what spec you got in mind? And I would see Gary crazycage
Old Nov 8, 2015 | 07:37 PM
jay030787's Avatar
jay030787
Lol just talking to him now on Facebook
Old Nov 8, 2015 | 07:41 PM
stuart collins's Avatar
stuart collins
hope u got big money to spend, wats your spec for 450bhp ?
Old Nov 8, 2015 | 07:42 PM
little bram
Got my driveshafts made by him they are great good quality work.
Old Nov 8, 2015 | 07:44 PM
jay030787's Avatar
jay030787
It's flat out not much else I can get on it lol am running 300 + at the moment and just on with changing my management and sorting my inlet manifold out then will see how well it holds together lol
little bram
That's what I was thinking Stu you'll know with sticking with the cvh
Old Nov 8, 2015 | 07:45 PM
little bram
You got any pictures?
Old Nov 8, 2015 | 07:52 PM
stuart collins
whats flat out ? yours ? 300bhp isnt hard to get from a 1.6cvh , 350 is thats why there is hardly any of them around
Old Nov 8, 2015 | 07:55 PM
jay030787's Avatar
jay030787
Mine had had everything I can have on it so it's as strong as it will ever be so its just now down to mapping and seeing what I can get
Old Nov 8, 2015 | 08:00 PM
stuart collins
oh right, what u done bout oil pump? what u done bout valve train? what u done bout head lifting ? what u done about block?
what cam and turbo u using ?
u on mtx box?
Old Nov 8, 2015 | 08:07 PM
jay030787's Avatar
jay030787
Am just running burton high pressure pump at the moment it's got a burton cnc head Newman cam solid lifters arp studded block and it's got a t3 hybrid turbo done at cr turbos it's got all sorts am not out there to brake records and to have it last for ever I use it in summer in nice weather so that means 2 weeks of the year lol am just going to see what I can push out of it as my times costs me nothing and I love seeing what can be got out of the smaller engines
Old Nov 8, 2015 | 08:08 PM
little bram
I think nms run a modified s1 manifold that gets them to 350. Don't know what they use after that point.
stuart collins
u will also find every few tuners who will try mapping a cvh to 400+bhp as it will more than likely shit its self
Old Nov 8, 2015 | 08:11 PM
jay030787's Avatar
jay030787
Lol that's why am mapping it if it does then it does I will then put a 1.9 long stroke in it or zvh but will have some fun with this one first
Old Nov 8, 2015 | 08:12 PM
stuart collins
your turbo is already near max at 300 u wont see much more out it
Old Nov 8, 2015 | 08:13 PM
jay030787's Avatar
jay030787
I no it's built to take 30 psi then I will have to look at something better not sure what yet
Old Nov 8, 2015 | 08:22 PM
stuart collins
pump will be a problem
head will still lift
needs different turbo
what size boost pipes , intercooler
what size exhaust system and down pipe u running( id hope your already on cossie t3 and down pipe)
i had loads of problems with rockers , studs , caps , collets all failing and dropping valves
Old Nov 8, 2015 | 08:25 PM
stuart collins
what rods, pistons, compression u running , wat injectors ?
jay030787's Avatar
jay030787
I will keep an eye on my pressure lol what turbo would you recommend and it's only on 48 housing and 3 inch exhaust at the moment
Old Nov 8, 2015 | 08:27 PM
jay030787's Avatar
jay030787
It's running at near to 7 on compression it's on accralite pistons and burton h beam rods
Old Nov 8, 2015 | 08:34 PM
stuart collins
proper low then , prob is at that comp need a massive turbo to make the power and it will be laggy and not drive well power band of 2k-3k
Old Nov 8, 2015 | 08:37 PM
stuart collins
id be phoning owen developments or turbo dynamics and asking them that. tell them wat u want and trying to do and they get some custom built turbo for u but be 1500-2k i would think
jay030787's Avatar
jay030787
Yes I might get it up a bit when it next comes to peaces will see lol what size exhaust housing would you say I will need to get 400 will it need to be a 63 or would I get away with a 55
Old Nov 8, 2015 | 08:38 PM
jay030787's Avatar
jay030787
And yes I will do thanks for your help
Old Nov 8, 2015 | 08:41 PM
stuart collins
wat turbo
Old Nov 8, 2015 | 08:43 PM
little bram
Would think you will need to go gt30 maybe 76 with the compression you have to get somewhere near 400
Old Nov 8, 2015 | 08:45 PM
jay030787's Avatar
jay030787
I will be lifting my compression it was a so called expert who said it needed to be that low so that will help get rid of some of my lag I will ring up about the turbo tomorrow and am on with sorting the manifold now
Old Nov 8, 2015 | 08:47 PM
little bram
New Pistons?
Old Nov 8, 2015 | 08:48 PM
jay030787's Avatar
jay030787
Mybe but will do a cc test myself and see if it can be taken from the head and block but will see
Old Nov 9, 2015 | 04:46 PM
russ rs's Avatar
russ rs
Most won't full stop because they shit them self
Old Nov 9, 2015 | 05:50 PM
jay030787's Avatar
jay030787
Well we will find out
Old Nov 9, 2015 | 06:02 PM
little bram
So is Gary making you a manifold?
Old Nov 9, 2015 | 06:10 PM
jay030787's Avatar
jay030787
He was on with details but he has vanished off Facebook
simontrayler
Mar 22, 2016 09:45 PM
cossirob
Oct 20, 2015 10:16 PM
lockie
15
Oct 16, 2015 09:59 PM
Slimm91
Oct 16, 2015 08:52 AM
Slimm91
Oct 15, 2015 10:30 PM
