Swapping bell housing on frs box to fit cvh
Old Nov 7, 2015 | 02:39 AM
Rsturbo519's Avatar
Rsturbo519
Default Swapping bell housing on frs box to fit cvh
Hi guys hoping for a little help before I order some parts. I'm wanting to fit a mk1 frs box to my cvh. As you know the started is at the back on the frs box - Can someone confirm that I can use the bell housing off another mtx box to relocate the started position?
Also what clutch / flywheel
Thanks
Old Nov 8, 2015 | 08:14 PM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
Thanks
You can swap bellhousings, i think the rs2k is a front mount starter.
As for clutch, going to be a mash up, I'd go for a frs flywheel and use a sach frs clutch. Might need a little work to clear bell housing, but very minimal.
Old Nov 8, 2015 | 08:20 PM
RIB1122's Avatar
RIB1122
you might need to use the full box mate, some mix boxes have have extra bolts around the top and bottom case!!!!
Old Nov 8, 2015 | 09:07 PM
McCloud 85's Avatar
McCloud 85
You could use a starter housing cut from another bell housing (the CVH B5 gearbox for example) then using the gearbox sandwich plate on the CVH use this to line the housing up on the MTX box and weld it in place.
The only reason why I mention this is because it was the way I used the ib5 box in the Ka with the frst engine. The Ka starter is on the back and the CVH needed it on the front, this was the quickest and easiest way of get the starter in the right place without messing about with taking the box apart.
What I don't know is if you could then use the CVH flywheel and suitable clutch and if the input shaft on the MTX box would fit the clutch?
Old Nov 8, 2015 | 11:43 PM
Rsturbo519's Avatar
Rsturbo519
I think a mk2 mondeo 1.8 or 2.0 diesel bell would go straight on but would like someone to confirm this. It would be great if I could stay mechanical speedo as think that housings are. They are hydraulic clutch anyway which suits me as clutch conversion seems easy to do
Old Nov 8, 2015 | 11:47 PM
Rsturbo519's Avatar
Rsturbo519
I don't think the clutch would accept the mtx input shaft as would be bigger. Think mondeo mk2 diesel bell housing onto my frs box is the answer. I hope so anyway lol
Steve Escos
Apr 2, 2016 09:05 PM
SteveW
Nov 26, 2015 03:24 PM
Chas
Ford Focus RS
Nov 14, 2015 04:36 PM
steveo3002
Nov 6, 2015 01:50 PM
bailes53
Nov 3, 2015 05:10 PM
