Ford Fiesta The Iconic Ford Fiesta started in 1976 and ended in 2023 bringing to a close this great cars run of almost 50 years.
Fiesta mk6 1.6 idle issue
Old Nov 5, 2015 | 09:59 PM
Tez3054's Avatar
Tez3054
Exclamation Fiesta mk6 1.6 idle issue
Hi folks, hope someone can help me here am stuck
She's a 1.6 zetec se 52 plate 138000 miles
No engine management ligh on or stored codes
Here's what's happening
Start car as normal form cold idles as it should sounds as it should when you rev engine,
The problem starts when she starts to get warm (choke off) the idle become's very rough like a miss fire if I rev her up sound and runs as it should till you release the throttle and then it just cutts out no idle what's so ever, don't know what els to do plz help
We have changed
The throttle body
The manifold ( all of it )
Maf
Injectors and and all the wiring
Coil pack leads and plugs
Camshaft position sensor
Lamda
Old Nov 6, 2015 | 07:45 PM
RichieST's Avatar
RichieST
What about the idle control valve?
Tinshaw
18
Dec 12, 2015 09:58 PM
Slimm91
Oct 16, 2015 08:52 AM
Slimm91
Oct 15, 2015 10:30 PM
Matthew Buckel
Oct 14, 2015 01:57 PM
PaulT
Oct 10, 2015 02:33 PM
