Please help my car doing my nut in lol
Old Nov 3, 2015 | 03:39 PM
Craigsteen rs's Avatar
Craigsteen rs
Default Please help my car doing my nut in lol
Hi guys my fiesta rs turbo engine is spitting in side the engine when you try to rev it up I just built the engine bottom to top for my Orion its start fine but when you try Rev or put the car under load it's spitting like mad thanks guys
Old Nov 3, 2015 | 04:17 PM
Caddyshack's Avatar
Caddyshack
Spitting? Do you mean missing as in mis firing?
I would start with all the normals, timing, earths, plugs and leads, injectors...the list goes on and on but you will need to rule each out.
Old Nov 3, 2015 | 04:24 PM
Craigsteen rs
I change leads plugs coil took the 701 beige injectors out put the standard ones on still no change its like its detonating when try Rev or drive
Old Nov 3, 2015 | 05:51 PM
Is the timing spot on.
Old Nov 3, 2015 | 05:53 PM
Rob_DOHC's Avatar
Rob_DOHC
As above, check the timing. Then check your plug gaps... then your ignition coil.
Old Nov 3, 2015 | 08:24 PM
wildheart's Avatar
wildheart
I had the same problem on a cvh, ended up being a faulty batch of plugs!
JasonPD
Oct 22, 2015 07:29 AM
paceo
Oct 16, 2015 02:14 PM
PaulT
Oct 10, 2015 02:33 PM
Mini193
Oct 5, 2015 07:58 PM
