Sierra Cosworth front brake pipe pics info/pics plZ???
Old Nov 2, 2015 | 05:42 PM
bull-turbo's Avatar
bull-turbo
Default Sierra Cosworth front brake pipe pics info/pics plZ???
Hi I got a sierra 3dr Cosworth an just redone most brake lines, but can't remember how they go as its been so long!!😞 so Tia for any info an pics would be better!! It's running no abs now, done the bulkhead ones but stopped at crossmember ends with female ends on. So does anybody have any pics plZ as don't know how to do them to the flexi pipes on the front??? Thanks for any advice Tia?????
Old Nov 2, 2015 | 05:46 PM
Caddyshack's Avatar
Caddyshack
I don't really know quite what you are asking for, normally the pipes just drop down through the inner wing and the pin the male end screws in to the female part of the flexi.
There must be hundreds of caliper, engine bay and inner wing pics on google if you just type cosworth front brakes in to google and hit images.
Old Nov 2, 2015 | 05:57 PM
bull-turbo's Avatar
bull-turbo
Wen I done a search the hubs in the way an can't see properly. At the end of crossmember there's holes. I've stopped there an female ends on but don't now if they go there an if I make another up further in inner arche an use any other fittings not to sure? Hope this helps
andyrst88
Oct 22, 2015 09:19 PM
disco-stu
Oct 18, 2015 05:23 PM
Mark V8
Oct 16, 2015 03:09 PM
Cossy Mike
Oct 12, 2015 04:37 PM
