Aftermarket steering locks
Old Oct 31, 2015 | 01:01 PM
ajamesc's Avatar
ajamesc
cossie fan (unluckerly)
Default Aftermarket steering locks
Do things like stop locks fit on smaller RS 4 spoke steering wheels? Anyone used anything on one
Old Oct 31, 2015 | 03:25 PM
rogerxr3i's Avatar
rogerxr3i
disklok's come in different sizes,
measure the circumference of the wheel then go on there website to see which size is better,
i did that for my golf and then bought a pre owned off e bay,
best security device i bought...
Old Oct 31, 2015 | 03:51 PM
Oranoco's Avatar
Oranoco
Disclock is what you want and don't forget to modify it. None of the other steering wheel locks come close and buy you next to no time at all
Old Oct 31, 2015 | 04:54 PM
Disklok
Old Oct 31, 2015 | 05:15 PM
cozzy jeff's Avatar
cozzy jeff
recently done mine,note:im a bricklayer not a welder so don't knock it lol.
Old Oct 31, 2015 | 05:34 PM
ajamesc's Avatar
ajamesc
You have beefed that up! I'll have to measure my steering wheel at some point and go on there web page
Old Nov 1, 2015 | 01:03 AM
Adam-M's Avatar
Adam-M
A small disklok will fit an rs4 spoke James, I've got a 3 spoke and four spoke and have compared them to a cossie wheel and are similar sized. I've got a small disklok on the cossie wheel and it's fine.
Old Nov 1, 2015 | 06:02 AM
2wdsaph ben's Avatar
2wdsaph ben
Got mate to modify my one. Yes it is smallest size disc lock do
Old Nov 1, 2015 | 07:42 AM
gcfcos's Avatar
gcfcos
Nice mods on the locks there. I don't bother anymore as they had mine off in seconds and trashed the leather steering wheel and cowling, column and stalks. Better off with a snap off steering wheel?
Old Nov 1, 2015 | 08:04 AM
Adam-M's Avatar
Adam-M
Did you have the same one as above mate?
Old Nov 1, 2015 | 08:06 AM
gcfcos's Avatar
gcfcos
No sorry mate my mistake I had the bar type one with the yellow clamp on the end
Old Nov 1, 2015 | 08:07 AM
gcfcos's Avatar
gcfcos
Krooklock I think it was called
Old Nov 4, 2015 | 09:24 AM
R4N SS's Avatar
R4N SS
I need to get my disklok modified - anyone help me out?
Old Nov 4, 2015 | 04:48 PM
2wdsaph ben
Only need two metal bars welding across back to make hole smaller and weld around top lock and bottom hinge. I have my mate a tenner to do mine as can't weld, then I sprayed it in with some old paint I had
Old Nov 4, 2015 | 04:52 PM
ajamesc's Avatar
ajamesc
if you can get the metal I can do it
Old Nov 4, 2015 | 05:16 PM
dojj's Avatar
dojj
Resident Wrestling Legend
as a visual detterent they are fine, but anything else they were shit
Old Nov 5, 2015 | 04:04 PM
R4N SS's Avatar
R4N SS
nice one mate - i will ask a few people and try and get some metal in that case.
Old Nov 5, 2015 | 04:12 PM
ajamesc's Avatar
ajamesc
No worries I can cut the metal we just don't have any good bits about
Old Nov 6, 2015 | 02:24 PM
R4N SS's Avatar
R4N SS
excellent
Old Nov 6, 2015 | 02:26 PM
Caddyshack's Avatar
Caddyshack
Let me know how long you want the bits to be and a rough thickness of the metal .i.e. 4mm and I will look through my store, I tend to keep useful looking bits and recently cut up a go kart chassis so I expect there are some decent bits there and I am not that far - post would be easy.
Old Nov 6, 2015 | 03:34 PM
R4N SS's Avatar
R4N SS
I defo need some so if you can supply it i will buy it.
No idea on size as the car is locked in a garage in slough and im in basingstoke at the moment- I cant even remember the last time i looked inside the car now as its been in the garage for over 3 years now.
Also, worth noting, if you are going to use a Disklok - get a soft steering wheel cover to put over the wheel and then put the Disklok on otherwise it will wear the leather on the wheel
Old Nov 6, 2015 | 05:11 PM
Caddyshack's Avatar
Caddyshack
Let me see what I can find on sat, you don't need to buy it.
I have loads of 2mm thick but that is sheet metal. I think I have some 4 or 5 mm that I can send and you can cut, I will do a rough line with my plasma.
Old Nov 6, 2015 | 05:26 PM
R4N SS's Avatar
R4N SS
great - pm me please when you are ready mate
Old Nov 7, 2015 | 04:10 PM
2wdsaph ben
25x5 stainless bar I used for mine but could be thinner
salsheikh
Alloy wheels and ICE for sale
Nov 2, 2015 10:18 AM
Jonnyyoung2013
Oct 29, 2015 11:52 AM
rsturbolee
Oct 28, 2015 08:08 PM
JordanSpencer
Oct 28, 2015 11:56 AM
JordanSpencer
Oct 28, 2015 11:49 AM
