Sapphire Cosworth 4x4 Rear Hub/Disk/Backing Plate
Hi,
Rebuilding rear hubs and the backing plate that normally sits just off the disk now sits about 4" off the disk, proving difficult as I never took it apart I'm just rebuilding it.
I can see how it can go any other way.
Currently I have the cross member/backing plate/hub/disk, the only thing I can think of is the disk is more shallow with it being vented vs a solid disk?
Thanks
Thanks
Hi,
Thanks
Thanks
I have vented disks, I just think the gap between the backing plate and the disk is a bit big.
I just presumed the vented and solid disks may have been different hence the space between plate and disk.
I will have to try and scour the site to see if I can see anyone has taken a picture of the hub disk and plate.
Quaver
Nov 3, 2015 01:32 PM
Mark V8
Oct 16, 2015 03:09 PM
Chas
Oct 11, 2015 08:21 PM
