Abs help going insane!
Old Oct 26, 2015 | 12:52 PM
Harryh24's Avatar
Harryh24
Default Abs help going insane!
I've been trying to sort my abs out on my 3 door. I'm guessing before I had the car the abs had been bodged as words were joined to make it run all the time. I've put all wiring back to how it should be and the I turn ignition on but nothing happenes.
The warning lights come on bit that's it.
I've replaced:
another Ecu
Both pressure switches in the pump
All speed sensors
All fuses / relays but not for original not sure if would make any difference but the originals weren't in there to start with so not sure what ones they are.
I'm just stuck and it's all I need to be able to drive the car after nearly 4 years of a restoration!
Old Oct 26, 2015 | 01:24 PM
dojj's Avatar
dojj
Resident Wrestling Legend
do you have power when you turn the ignition to position 2? the radio one bit?
has the dash come apart? there were 2 plugs behind that under the windscreen, one for the fusebox and one for the ignition power, has someone unplugged these and not plugged them back again?
you've not burnt out the fuseable link from the battery?
Old Oct 26, 2015 | 01:52 PM
Harryh24's Avatar
Harryh24
I have power the pump runs if I bridge the relay so there is power to everything. Just not sure why the thing doesn't work lol
Old Oct 26, 2015 | 02:11 PM
Harryh24's Avatar
Harryh24
When Should the pump prime?
As I've now found a wire and swapped with another one and now the pump works but doesn't stop running! On first and second position. But the pedal is still hard and I get nothing from the rear?
Thanks
Old Oct 26, 2015 | 07:57 PM
dojj's Avatar
dojj
The punp needs to run for a few second to build up the pressure but from position 1
Constant running burns it out
Old Oct 26, 2015 | 09:19 PM
Harryh24's Avatar
Harryh24
Sorted it all now, turns out the pipe that feeds it was kinked so wasn't getting any brake fluid. Thank god it's fixed haha
Old Oct 26, 2015 | 10:12 PM
dojj's Avatar
dojj
See? Easy
Old Oct 29, 2015 | 11:44 AM
cossynut2's Avatar
cossynut2
10 Year Member
Smashing when something turns out to be a simple fix when you are getting worried its going to be a nightmare!!
2Litre
Oct 11, 2015 08:30 PM
Sierrasideways
Oct 7, 2015 07:59 PM
