Cosworth idle problem
Old Oct 23, 2015 | 01:24 PM
B13 JUS's Avatar
B13 JUS
Default Cosworth idle problem
I've got a idle problem on my Saph 4x4.
I've had the engine fully rebuild and on first start up it started fine byr idled low all the time.
when it was warmed up the idle was delayed a few seconds after reving it up
So I thought I check tps and it showed 0v closed and 4.5 open throttle
now I've set it to 0.35v closed and its 4.8v open.
Now I can't have the icv plugged it as it revs very very high.
I've set the idle too 1000rpm when warm so idles perfect when warm.
I've also tried another icv and its the same.
Any ideas what's wrong?
Old Oct 23, 2015 | 04:10 PM
oldford's Avatar
oldford
TPS at idle should be below 0.30v. Ideally set it to 0.17v or close to that voltage.
Idle rpm is set to high, should be below the idle rpm the ecu wants.
Old Oct 23, 2015 | 08:28 PM
B13 JUS's Avatar
B13 JUS
I'll try these settings and see how it goes, I did get the other settings of here.
james kiely
18
Nov 26, 2015 07:06 PM
cortina41-2008
Oct 21, 2015 10:22 AM
timsrs
Oct 11, 2015 01:56 PM
PaulT
Oct 10, 2015 02:33 PM
