Anyone used a MSD fuel pump loom?
Old Oct 22, 2015 | 05:34 PM
mrmann's Avatar
mrmann
Default Anyone used a MSD fuel pump loom?
This is the second one ive had off them for the same car and the instructions dont relate to the relay.
First one i had off them there was a pink wire coming out at the fuel pump end.
The second one has a blue wire coming out.
The instructions refer to a black open ended wire that does not exist and do not refer to the pink or blue wiring.
anyone shed any light on this?
Old Oct 22, 2015 | 07:10 PM
The Youth.'s Avatar
The Youth.
hi Ken, best give them a ring, but without seeing it is the spare wire at the fuel pump end not the trigger wire that goes onto the original feed to the pump?
when I built mine I put the relay at the front and used the original fuel pump feed in the ecu harness as a trigger for the new relay
steve
Old Oct 22, 2015 | 08:30 PM
mrmann's Avatar
mrmann
I assume the blue wire is the trigger as on the instructions it is a black wire that isnt there.. so this could be just a mistake on instructions
Old Oct 22, 2015 | 11:58 PM
rdvil's Avatar
rdvil
Thin wire is naturally the trigger, thick are the power wires. You can trigger it from the original fuel pump + or ecu's fuel pump relay trigger if you find it under the dashboard.
Related to this, anyone managed to fit their adapter to 044 Bosch without it leaking?
Old Oct 23, 2015 | 12:44 AM
The Youth.'s Avatar
The Youth.
My MSD adapter fitted perfectly, the one I had before from another company leaked
steve
Old Oct 23, 2015 | 10:56 PM
Guinnless's Avatar
Guinnless
steve
Mine fitted fine too.
Old Oct 27, 2015 | 11:58 PM
rdvil's Avatar
rdvil
Guess I was just unlucky then. Included washer didn't hold at all and even replacing it with a copper item didn't help. Hopefully figure out something to sort it before spring.
Old Oct 28, 2015 | 07:08 AM
JamesH's Avatar
JamesH
Try with a dowty washer. Even though they're designed for extremely high pressure, it may work
westyre1
Nov 20, 2015 10:36 AM
swcortina
Oct 23, 2015 09:41 PM
Tank Mike
Oct 21, 2015 06:22 PM
Sierrasideways
Oct 18, 2015 11:05 AM
mrmann
Oct 17, 2015 04:01 PM
