Any VW techs on? Need a bit of help/advice!
Old Oct 20, 2015 | 08:34 PM
xr2john's Avatar
xr2john
Passionford Addict
Default Any VW techs on? Need a bit of help/advice!
Hey folks, got a problem that I'm sure someone on here can help me as there's a lot of very knowledgeable folks on here who have helped me out in the past
Mrs has got a 55 plate Touran Tdi 105 model. Bought it 4 months ago and has been perfect and done 6k miles in that time and hasn't missed a beat. Had a family crisis in Aberdeen today so popped the kids to school first thing and headed up, 55 miles from door to door. About 10 miles up the dual carriageway there was a strange whistling noise about 70 which I had noticed a few times before,sounded like wind noise coming in a rear seal but it started annoying me so stopped and checked all the doors etc and off we went again. Came and went a couple of times on the way up then stopped anyway ran about in Aberdeen doing a few things and then headed home about 2 hours ago to pick up the kids from freinds. Sat at 75 all the way home on the dual carriageway and then pulled off into Forfar .50 yards up the road it spluttered and lost power. Still running just not revving right but no management light or rattles. Sounds fine until you try to rev it but sounds squealy and a bit of smoke when revved. Opened the bonnet but it's pitch black but with my phone could see the pipe on the left of the engine cover had collapsed. Switched it off as was just round the corner from home and it had went back to normal. Fired back up and still the same.
Any ideas folks?? Anyone experienced the same or just know what it is?
Got a few ideas what it could be but really not sure where to start with it and what to check. Quite happy to pull it apart if needs be but would like some advice where to start.
I would ask on a vw forum as I did sign up to 1 when we got it but I asked a few questions about more power etc and not much help at all. Forum felt a bit cleeky
Had a really shit few days and this is all we need
All help will be really appreciated
Old Oct 20, 2015 | 08:54 PM
Caddyshack's Avatar
Caddyshack
Go on to VW caddy forum, they are a nice bunch, say Toby / Caddyshack sent you and they will give you the answer.
I suspect it may be in limp mode but would expect engine light. Obviously the collapsed pipe needs to be replaced. It could just be that or a blockage further up making the pipe collapse.
My Range Rover did similar and it was a tiny crack in a boost pipe that only opened up under higher boost.
You can buy fault code readers for next to nothing, plug it in and then google the code. You can buy vag com leads on eBay.
Old Oct 20, 2015 | 09:49 PM
xr2john's Avatar
xr2john
Passionford Addict
Cheers for the advice. I will register and ask as boost leak was my 1st thought. That or the turbos gave up. It's done 122k so it wouldn't be unheard of. Going to phone the AA in the morning and see what they come up with as I have full cover but after the day I've had I just couldn't be arsed with it. It was close to a few kicks but I had to stop myself
Like I said 1 of them days but tommorow a new day thank fuck but cheeRs again
Old Oct 21, 2015 | 04:24 PM
The Transplanter's Avatar
The Transplanter
I have replied to you post on the Caddy Forum
Al
Old Oct 21, 2015 | 04:42 PM
Caddyshack's Avatar
Caddyshack
There you go, the forum owner even responded!
xr2john's Avatar
xr2john
Passionford Addict
Al
CheeRs.
Old Oct 21, 2015 | 04:50 PM
xr2john's Avatar
xr2john
Passionford Addict
Can't say better than that Will be a regular from now on I think
Old Oct 21, 2015 | 05:11 PM
Caddyshack's Avatar
Caddyshack
They do some lovely bits in the shop and the forum is really friendly so a great place for the VW stuff, a bit like PF
Old Oct 21, 2015 | 05:40 PM
xr2john's Avatar
xr2john
Passionford Addict
Yeah seems to be Been looking for a new forum to nose around so glad I took your advice
StephenC
Oct 9, 2015 09:33 PM
DPDISXR4Ti
Ford Fiesta
Sep 21, 2015 03:51 PM
Bransby
Sep 11, 2015 01:09 AM
kevin36
Sep 2, 2015 06:24 PM
cossirob
Aug 31, 2015 09:53 PM
