Stage 2 Turbo - What other mods required?
Old Apr 5, 2005 | 04:12 PM
Big Will_'s Avatar
Big Will_
Borg Warner EFR Equipped!
From: In the unit, building a 450bhp Time Attack Focus!
Default Stage 2 Turbo - What other mods required?
Hi all,
If i was planning to run a Stage 2 Hybrid turbo, what other mods would i need to consider?
Pricing up a rebuild of a worn standard engine and don't want to buy anything i don't need
Will
Old Apr 13, 2005 | 10:08 AM
SteveRS1980's Avatar
SteveRS1980
hi m8 u could get a chip for ur ecu,-31 actuator,piper cam kit,turbo oil feed,bigger intercooler ie pace or pro alloy hope this helps m8 good luck
Old Apr 13, 2005 | 11:25 AM
zvhrst's Avatar
zvhrst
as said above- shoul see you easily for 200bhp
Old Apr 13, 2005 | 05:29 PM
HybridBly's Avatar
HybridBly
you gunna go for a low comp rebuild? agree tho with those mods very good power. Good Luck
Thx Jon
Old Apr 13, 2005 | 09:36 PM
wildheart's Avatar
wildheart
Have a look here
www.norrismotorsport.co.uk
Old Apr 13, 2005 | 10:02 PM
nigel b's Avatar
nigel b
low comp
standard cam
h/d big end bolts
large i/c
chipped ecu
-31
and more if you want
Old Apr 14, 2005 | 08:46 AM
JesseT's Avatar
JesseT
FIRST decide what you want. Power, power band, driveability, MPG, max boost, etc... THEN you can decide what mods you want to do.
Some things just don't go together well.
big_Rad
Sep 15, 2017 09:36 AM
SmudgerByName
52
Jul 28, 2016 06:14 PM
Matt Baxter
Sep 16, 2015 08:30 PM
mrknifey
Aug 30, 2015 11:48 AM
oilman
Trader Parts for Sale.
Aug 30, 2015 08:37 AM
