Number 4 plug getting wet ?
Number 4 plug getting wet any ideas?
Recently my car started missing. Checked it out and found number 4 plug to be wet with fuel. Cleaned plug swapped for another from cylinder 4, re started and run fine then after a few mins miss fire again, same problem number 4 wet. Done compression check and all ok, good spark too and injectors are only 800 miles old. It's run perfect for 800 miles denso plugs. Any ideas before I pull it apart again?
I've had the same problem this week with denso plugs,thought the engine shit itself for a start and then started with the basics and turned out to be a duff plug.
They're only a couple of hundred miles old too
Cheers guys going to have a look tomorrow was really impressed so far with denso plugs much better than the fords ones, until now maybe it's the plugs well fingers crossed!
same for me mate on no3 using densos. I found short runs and moving car about caused issues.
Put 071's in it should be fine.
Also swap injectors as said just in case.
Paul
Paul
Mark
Had a play with it today and found 2 of the densos getting wet, changed them for ford plugs and took it for a spin, plugs not getting wet but now have an intermittent miss 1 cylinder dropping out for some reason. Il have another look tomorrow.
Fatphil
Oct 15, 2015 10:02 PM
Matthew Buckel
Oct 14, 2015 01:57 PM
Brocker
Oct 12, 2015 07:00 PM
