YB cam cover
Old Oct 17, 2015 | 06:48 PM
jamie956's Avatar
jamie956
Default YB cam cover
Can a 2wd cam cover be converted to take a screw type oil filler cap, I have a brand new twist cap but still keeps leaking on my crackle black cover which is a twat to clean off
Old Oct 17, 2015 | 11:25 PM
cossiestu's Avatar
cossiestu
Might not be economically possible, if it's even possible at all?! Not wanting to ask a stupid question, but has the crackle finish been machined off where the cap seals? I'm assuming the bayonet fit caps are no longer available?
Old Oct 18, 2015 | 12:32 AM
jamie956's Avatar
jamie956
Yer flatted off and new cap from GGR still weeps only a tiny amount but just enough to piss me off.
Old Oct 18, 2015 | 07:10 AM
cozzy jeff's Avatar
cozzy jeff
can you not add another or a thicker seal to the cap?
Old Oct 18, 2015 | 09:16 AM
turbotrev's Avatar
turbotrev
Yeah try another seal if possible
Cheers Paul
Old Oct 18, 2015 | 04:24 PM
gcfcos's Avatar
gcfcos
I'd say if it's been machined you'll need a very slightly thicker seal?
Old Oct 18, 2015 | 05:25 PM
jamie956's Avatar
jamie956
Not machined just flatted off back to alloy, will have to look at the seal.
Old Oct 19, 2015 | 03:28 PM
PAUL S's Avatar
PAUL S
Buy a cheapo cap from a motor factors for a VW bayonet type and use the seal from that, they are the same, did that myself years ago.
timsrs
Oct 17, 2015 09:05 AM
Chas
Oct 16, 2015 07:08 AM
