no heater no rad fan no indicators
Hi can someone help I have no indicators, no rad fan, and no heater tested all relays and they are fine I have hazards I don't have power at the fuse's for any of them can someone help ??
Theres a post about this on here ive seen before. Im sure theres 2 white relays together on the fusebox. Take them out and clean connections.
A lot of people commented on the post with the same trouble
your testing for power with the key on position 2 ?, ,
main power is fed upto the ignition switch , . and . .
is distributed as the key is turned to position 1 position 2 and cranking on position 3 , pretty sure the little white relays are headlights. so not related to your issue,
Not had anything go wrong with the locking, the EGR valve went tits up, but, only other fault is no heat coming out...
Called Vauxhall today, they will call when the part is in stock...
eventualy got to the bottom of the problem the fuse box is melted through wires corroded touching underneath fuse box drawing currant away from the the relay so check all the wires underneath the fuse box
fordrallycar
Oct 11, 2015 12:55 PM
