General Car Related Discussion.To discuss anything that is related to cars and automotive technology that doesnt naturally fit into another forum catagory.
must be a load of faulty 071s being sold,bought a set from matt lewis,2 wouldnt work at all,got another set from ford dealer again only 2 would work,if i put the 4 good 071 runs great, new set of ngk iridiums work no problem
I just put a set of 071's in mine and one of them didn't work
Had the same issue - bought a set of 4 and one was dead, put an old one back in and ran fine. Ended up just cleaning the old set and sticking with those!
ran denso s for years and never had a problem,
changed to 071 s and they didnt even last the summer, fucked already,
a mate of mine had problems with 071 s as well
I ll prob go back to the denso s again now
A faulty 071 cost me my first race of the season, put 4 new plugs in after qually then on the green flag lap I came on boost for the first time and it would barely run!
pulled off after half a lap, hurts when it costs 300 quid and you do half a lap!
got loads more 071's and did a test day swapping them around till I got a few good known working sets
Because i'd never had an issue with them previously and had several sets in stock, I completed the rest of the season without having to take them out again.
For next season I will move to a different plug yes
Iv just had 2 densos give up after 200 miles and a set of 071's started missing after 300 miles! Got a combination of the 2 now just to get the car running on 4 cylinders.
I have had the same set of Denso Iridium plugs in my car for the last 18 months with no problems at all. I cant understand why you have had 2 fail in such a short distance. I have got wasted spark ignition, maybe that helps?
You clearly have a problem that you need sorting before you kill your engine.
Mark
Maybe there is a problem that is causing them to break down then. Have u got any ideas what it could be? The car is on a low boost base map to run it in and is not ragged everywhere just a quick blast now and again.
Do you have a afr gauge in the car and is it live on start up.
