cossie probs AGAIN!
Old Apr 5, 2005 | 02:46 PM
stesrst's Avatar
stesrst
Default cossie probs AGAIN!
Just got home in my 2wd saff as i pulled up the brake pedal went solid and i had very little braking effort, i lifted the bonnet and there was a buzzing/clicking noise from the black canister near the servo.
switched the car off left it five mins then took it round the block and its fine. has anyone delt with anything like this before?
Old Apr 5, 2005 | 08:15 PM
stesrst's Avatar
stesrst
anyone? been out in the car a couple of times since and it seems fine, just a bit concerned it might do it again but when im giving it some
Old Apr 5, 2005 | 09:25 PM
richm's Avatar
richm
sounds like the ABS pump was running continuously and over pressurising the system..
Check the condition of the connectors and their contacts around the brake master cylinder and pump, especially the 7-pin one on the pressure switch, it is this switch that turns the pump off when the system reaches working pressure, via a relay, and if it isnot making good contact it can allow the pump to overrun.
I've had this once myself, but never did it again to absolutely trace the fault, But I think this was the reason.
gcfcos
59
Oct 6, 2015 05:04 PM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
A.t.p
Sep 29, 2015 05:04 PM
cossie330
Sep 27, 2015 04:13 PM
Russ Payne
Sep 25, 2015 08:29 PM
