ABS
Old Oct 11, 2015 | 07:54 PM
2Litre's Avatar
2Litre
Default ABS
Evening all,
Might be a silly question but does having a larger rolling radius tyres on the rear and smaller on the front effect the abs on a 3door? (ie-bring in fault lights)Or will the system compensate for this the same way it would when going round in a circle?
Cheers.
Tim
Old Oct 11, 2015 | 08:03 PM
dojj's Avatar
dojj
Resident Wrestling Legend
Won't make a difference
Old Oct 11, 2015 | 08:06 PM
Sierrasideways's Avatar
Sierrasideways
I thought the sensors get their readings from the teeth on the abs ring inside the hub. I'm not a mechanic so would actually like to learn
Philip.
Old Oct 11, 2015 | 08:30 PM
dojj's Avatar
dojj
When you are stopping it measures the difference between the counts and if it sees aaabig difference it does it's abs stuff
So unless you are putting radical different wheels on an inch wing make a difference
fordrallycar
Oct 17, 2015 08:53 PM
Anutternutter
Oct 17, 2015 04:34 PM
Chas
Oct 11, 2015 08:21 PM
Sierrasideways
Oct 7, 2015 07:59 PM
Fordmad!
Oct 6, 2015 07:35 PM
