205 YB engine, stripped and ready for assembly
This was a spare engine for my rally car, was just going to refresh as it was in good condition but now is no longer needed.
Its ready to assemble, which I was going to do, but this way people can see whats what without asking loads of questions.
205 block, standard pistons and steel rods, crank is .25 on mains and rods, new bearings and thrust washers, new oil pump, bottom end gaskets. Sump, water pump, flywheel, engine mounts etc all present. Head is 138.96 thick from my measurements, comes with inlet and throttle body, New Cometic head gasket and top set. Have a 2wd exhaust manifold I can thro in as well. May split it up if it does not sell complete. £2150, Cheers
