Fuel gauge intermittently dropping off, then works OK again.
Old Oct 7, 2015 | 01:49 PM
Sierrasideways's Avatar
Sierrasideways
Default Fuel gauge intermittently dropping off, then works OK again.
As above, the fuel gauge is intermittently dropping off, then works OK again.
I haven't dropped the tank yet but is this most likely a loose connection on top of the tank?
1st time it happened was going fairly quick over a bumpy potholey road (unusual in Ireland...NOT ) and it dropped to well well below empty. Then a few minutes later it came back up again.
I've also noticed that it only fills up to approx 95%, before it filled up higher basically.
Don't want to drop the tank unnecessarily as it'll take time and maybe it's not needed!
Also, another thread I just started has a problem in that the ABS light comes on when indicating right. Possibly related to the clocks or not...?
https://passionford.com/forum/ford-s...ing-right.html
Any help would be greatly appreciated.
Thanks.
Philip.
Old Oct 8, 2015 | 04:50 AM
4x4kiwi's Avatar
4x4kiwi
Hi Phillip
I had a similar problem a few years back that turned out to be a bad connection in a wiring loom plug in the back of the boot between the tail lights from memory. I removed the plug / socket and soldered the wires and haven't had the problem since. David
Old Oct 8, 2015 | 09:29 AM
Sierrasideways
Originally Posted by 4x4kiwi
Hi Phillip
Thanks David. I'll try that when I get a chance. Much appreciated.
Philip.
Old Oct 9, 2015 | 02:50 AM
cossie09's Avatar
cossie09
Default Fuel
Philip.
Hi Philip.it's the earth wire on the sender unit.the one on its own..
Old Oct 9, 2015 | 07:43 AM
Sierrasideways
Thanks Keith. I'll try what David said first and then if the problem persists, I'll drop the tank and fix the earth wire.
Philip.
Old Oct 17, 2015 | 10:25 PM
Sierrasideways
Default Sorted the issue.
Hi Phillip
Thank you David. It was just that said plug had a loose connection. All fixed now. Top man
Cheers,
Philip.
Flatlinedan
Sep 18, 2015 12:41 PM
Cossikev
Sep 13, 2015 02:00 PM
