Escort Range Ford Escort RS1600i / Mk. 5 & 6 / XR3 Discussion.
Trying to Fit a 38dgas on a 1.6cvh, is it possible?
Old Oct 3, 2015 | 09:22 PM
Jayy's Avatar
Jayy
Default Trying to Fit a 38dgas on a 1.6cvh, is it possible?
I have a 1600 cvh engine and was planning on fitting a 38dgas weber carb to it but the stud holes do not line up, but they are not too far off. Is it a simple case of elongating the stud hole on the carburettor and fitting it? Has any one done this before? Any help is much appreciated
Old Oct 3, 2015 | 10:12 PM
costina's Avatar
costina
Live long and prosper!!
38 dgas came from a 3 litre capri so it would overfuel a 1.6 cvh.
Old Oct 5, 2015 | 09:57 AM
djmca's Avatar
djmca
Bring back old skool Ford
Yes i did this before.
Just elongate the holes on the carb to fit the studs.
You will also need to bore out the holes on the top of the manifold to allow the butterflies to open and flow more air.
If you jet it correctly it will not overfuel but it may be a bit OTT, you could just use a carb for a 2.0 litre.
Old Oct 26, 2015 | 06:45 PM
Jayy's Avatar
Jayy
Thanks for your help, was swapping my 1400 for the xr3 engine, got the engine running now, fired it up for the first time and sounds sweet 👍🏻
timsrs
27
Oct 5, 2015 08:04 PM
sridgett
Oct 1, 2015 07:30 PM
Orion_Gav
Sep 29, 2015 04:50 PM
DavidK
Sep 27, 2015 02:55 PM
