Help please
Old Oct 3, 2015 | 09:01 PM
timsrs's Avatar
timsrs
Default Help please
Ive been having some issues with my car...
Hesitation when on light throttle.
lower boost pressure than normal.
Running rich.
When being revved the inlet is still in negative vacuum.
I have tried allsorts of thinks vac pipes OK, boost leak test OK
Then i was taking a look into the TPS....
I noticed that when throttle closed it would read 5v and as the throttle started to open the voltage would drop in line with the throttle opening..
Then it would jump back upto 5v with the throttle still slightly pressed.
it would seem to work ok when the throttle was more than 1/3 open...
But when fullt open it would fluctuate between 0.3v - 0.9v....
Could this be the culprit to all the problems over the last 2 weeks ???
Advice please..
Old Oct 4, 2015 | 12:21 AM
cossiestu's Avatar
cossiestu
Is there any way you could borrow TPS to try?
Old Oct 4, 2015 | 07:36 AM
timsrs's Avatar
timsrs
No unfortunately not. I will put advert in wanted section. Anyone rlse and thoughts on the symptoms im getting. Cheers
Old Oct 4, 2015 | 06:53 PM
timsrs's Avatar
timsrs
Anyone with anymore advice !
Old Oct 4, 2015 | 07:58 PM
cossiestu's Avatar
cossiestu
Sorry mate, I'm hopeless with anything electrical...
Old Oct 4, 2015 | 09:36 PM
Sierrasideways's Avatar
Sierrasideways
I have a PF09 for sale if you're stuck.
boeb
Jan 9, 2020 05:11 AM
timsrs
27
Oct 5, 2015 08:04 PM
Oranoco
Oct 3, 2015 11:26 AM
L1AM_RS
Oct 2, 2015 08:21 AM
