Fuel pump help
Old Oct 3, 2015 | 12:04 PM
Louis_RST's Avatar
Louis_RST
Default Fuel pump help
Replaced my crusty fuel pump cradle and pump last night.
When i went to pull the wiring connections of the old pump I discovered that someone had bodged some bullet connectors on which fell apart!
Does anyone know where I can get the correct yellow and black plugs from or is anyone breaking an RST or Sierra Cosworth with the plugs I need with a length of loom.
Any help would be greatly apprieciated as Im only using the car until the end of the month before sorning it for winter.
Old Oct 3, 2015 | 01:22 PM
RSmark84's Avatar
RSmark84
Shame I binned my factory fit one a couple of months ago after storing it for a few years. still had the ends on.
Consider buying a die(6mm?) and creating a thread on the connecting studs as im sure bosch was just a push on plug type? and fitting the eye and nut connector conversion?
Old Oct 3, 2015 | 02:02 PM
Louis_RST's Avatar
Louis_RST
It's a bit of messing around Mark, I'd rather get the push on plugs and solder them on tbh. I've emailed a few RST breakers on fleabay so hopefully someone will be able to help.
Old Oct 3, 2015 | 04:28 PM
RSmark84's Avatar
RSmark84
Always a last resort. Would be good if you fit the blue sytec banjo nut on the end of the pump to match the cradle.
http://www.ebay.co.uk/itm/Sytec-Bosc...item234eb6d5ba
I fit a red one on my car when I got the AS cradle.
Old Aug 2, 2021 | 04:39 PM
WhitwellMike's Avatar
WhitwellMike
Quick Question, how are the old connectors held? I press the 2 lock tabs and pull but they won't budge (been on 30 years) Is it brute force?
Thank you
RB26DETT
Feb 5, 2022 01:54 PM
155lee
Oct 27, 2015 04:55 AM
aprrrilia
Ford Escort RS Cosworth
Oct 10, 2015 07:14 PM
3doorcozmess
Sep 20, 2015 06:15 PM
