Hello! Question from Italy,please Help!
Old Oct 3, 2015 | 11:53 AM
akronos's Avatar
akronos
Default Hello! Question from Italy,please Help!
Hello i have an S2 from 1986. The car has a lpg equipment and works very well on standard boost ( 0,7 bar). I want to increase the boost pressure up to 1,0 bar ( 14 psi), and I know I can do it without having the LPG many problems because the octane number is higher. There 's a way to increase the pressure without reprogrammed ECU? If i act on the solenoid (amal valve) ,i have a chance to increase boost?
Old Oct 3, 2015 | 12:01 PM
akronos's Avatar
akronos
Pics show the LPG !
Old Oct 16, 2015 | 07:13 AM
Versus_Creations's Avatar
Versus_Creations
Ask me a question!
LPG is low on lubrication for your engine. Why have you switched. ?
Old Oct 16, 2015 | 10:45 PM
tasos77's Avatar
tasos77
rs turbo from Greece...
i think fuel price per ltr is the key jano..
Old Oct 25, 2015 | 07:18 AM
Beach's Avatar
Beach
Love to see some pictures of an LPG rs turbo. Whats the fuel prices like there ?
Old Nov 11, 2015 | 07:59 PM
Chas's Avatar
Chas
While this is true it does not have to be the case . You can either inject a lubricant in upstream towards the tank or have something going into the engine via vacuum which many cars use. Of course with a turbo car, a one way valve would be required for this .
Do you have more shots of the LPG and what kit/type of LPG injection it is? I am guessing it is a mixer ring type? I understand that LPG has a higher resistance to knock but of course adding lubrication to it may indeed knock it down in addition to having a high optimum AFR ratio by quite a way over petrol.
But IMO alot of it will hinge on the type of LPG system you are using .
Turbo1994
Ford Escort RS Cosworth
Oct 17, 2015 10:32 PM
Mark RS
Oct 12, 2015 06:01 AM
griffo69
Oct 4, 2015 11:58 AM
Rs_Motion
Escort MK 5 / MK 6
Oct 3, 2015 05:43 AM
