2.0L Zetec clutch kit on st170
Old Sep 29, 2015 | 08:16 PM
arkeye's Avatar
arkeye
Default 2.0L Zetec clutch kit on st170
Will it fit? I want to fit a solid flywheel with clutch on my st170 but the aftermarket kits cost a fortune so was wondering if it was possible to fit the 2.0L Zetec one as they are pennies when compared
Old Feb 20, 2016 | 01:22 PM
wombat76's Avatar
wombat76
several probs with that route, best you have a look on this thread about mtx 75 conversion the cars came with 2 different sized f/wheels, up to 2003 mid 230 and then 240 post that time, also getrag does not have same spline pattern, nor is the 2.0 std s/mass same depth as the st's D/mass f/wheel , the clutch needs to be sprung if S/mass unit is used.. see here for a decent look at whats needed..
https://passionford.com/forum/restor...onversion.html
jonfoc
16
Sep 11, 2018 05:35 PM
dombanks
Sep 21, 2015 08:38 PM
Billy_RS
Sep 13, 2015 04:17 PM
Adam Graham
Sep 6, 2015 06:04 AM
