Hello from Pro-Line Motorsport.
Old Sep 27, 2015 | 12:43 PM
PRO-LINE MOTORSPORT's Avatar
PRO-LINE MOTORSPORT
Former Sponsor
Default Hello from Pro-Line Motorsport.
Hi guys,
Thought we'd introduce ourselves on here now we are authorised trade sellers!
Pro-Line Motorsport are specialist in motorsport hose/fittings and assembly we cover every aspect of hydraulic/pneumatic hose/line for the automotive world.
From standard replacement to full motorsport dry kits, we do it all.
We are based in surrey and will soon be offering a mobile service, so trackside repairs or full car plumbing in your home garage can be done by us!!
We use only the best in the business when it comes to materials, the like of aeroquip, bmrs, earls, speedflow, mocal, hel performance, pwr, progold and many more. No cheap chinese crap here!
We have a few items in the trade/sale section but pls if there is anything you may need and think we be able to help, just ask!!
Mitch @ Pro-Line Motorsport.
Old Sep 27, 2015 | 02:07 PM
andy130's Avatar
andy130
welcome to PF
Old Sep 27, 2015 | 02:36 PM
Hello and welcome. I hope your business does well.
Old Sep 28, 2015 | 08:54 PM
PRO-LINE MOTORSPORT
Former Sponsor
As requested by many here are some pics of the range of hose and fitting available at Pro-Line..
We use Hel Performance fittings and hose for all brake and clutch applications, can also be used for turbo oil feeds, water, fuel and air. -3 Nylon ptfe lined, stainless overbraid with a pvc outer coating available in many colours as well as standard silver, black and carbon effect. All fittings are high grade stainless steel and are silver in colour except banjos which you have a choice of 6 colours and silver. -4 line and fittings available also in black, silver and carbon only.
We can also offer a strictly motorsport only option of smooth bore hose by brown&miller in a wide range of overbraid options from standard stainless, hp stainless, translucent, igf, pvc coated and kevlar. Fittings again are mainly silver with some specials available in anodised blue alloy. From -2 to -8
For fuel, oil, water and everything else we use a range of manufactures such as mocal, an elastomer lined hose with textile reinforcement and elastomer outer cover with stainless steel outer braided options available with a 1/2", 5/8" or 3/4 inner bore size, fittings are mild steel and require crimping, wide range of fittings available.
Aeroquip push on hose (socketless) available in blue or black elastomer inner and outer covering, fittings available in steel and red/blue or black/black alloy fittings, again a wide range of fittings available, very cost effective, easy to trim and assemble yourself. Available from -4 to -12. (Only blue shown in pic, ignore the other 2 lines)
Aeroquip swaged fitted line also available. as above but crimped fittings, available in silver/red
Aeroquip fc333 and g210 racing hose and fittings, an elastomer tube with stainless reinforcement with full stainless or black braided nylon outer covering, available from -4 to -16 fittings to be used are aeroquip re useable fittings, again, very wide range of fittings available, aeroquip fittings available in red/blue black/black or nickel plated alloy. Speedflow red/blue /black/blue or custom anodise.
A heat resistant kevlar covered hose is also available (aeroquip startlite).
Aeroquip and mocal tfe racing hose, basically the same as above except extruded teflon lined, available in stainless overbraid only. Available from -2 to -8.
Pic shown with speedflow fitting.
Bmrs ProGold lightweight racing hose, ptfe inner lined with a choice of stainless steel, polyester or high temp polymer (kevlar) over braid. convoluted inner ptfe allows for maximum flexibility and collapse resistant. The daddy of motorsport hose. Available from -6 to -32 suitable for crimped or reuseable fittings and again, very wide range of fittings and adaptors available, specials can also be arranged. Blue/gold or black/black fittings.
So there you go, our main range of hose and fittings...any question please ask!!
Old Sep 28, 2015 | 09:25 PM
smiley's Avatar
smiley
Hello mate liking the look of the black hose in the last pic so for future ref you could come out and quote or fit the whole car if needs be?
Old Sep 28, 2015 | 09:54 PM
Adam-M's Avatar
Adam-M
Welcome mate hope it goes well, a handy company to have on board for braided fuel lines ect
