Can anyone get Genuine Ford parts?
Old Sep 26, 2015 | 12:26 PM
The Enigma's Avatar
The Enigma
Default Can anyone get Genuine Ford parts?
I need a thermostat for my Mondeo daily, just wondering if anyone on here can get one at a decent price compared to the main stealers?
Cheers Rich
It's a 2004 2.0 Tdci Mondeo btw.
Old Sep 26, 2015 | 12:30 PM
RichieST's Avatar
RichieST
Is it overcooling? If so you will probably want the oil cooler thermostat as these are pretty common to go on the mk3 diesel Mondeos.
Old Sep 26, 2015 | 12:43 PM
The Enigma's Avatar
The Enigma
Yes it is mate. I had read about that one but couldn't actually find out where it was? I might as well change both at the same time I suppose?
Old Sep 26, 2015 | 01:55 PM
RichieST's Avatar
RichieST
See the red circled bit. I did it on my tddi, doable without taking the inlet manifold off but was a fiddle. Do the normal stat first as that's easy, if not then it'll be this one.
Old Sep 26, 2015 | 03:21 PM
The Enigma's Avatar
The Enigma
Thanks for that. I've had the inlet manifold off before to clean it out and the EGR valve. It was pretty full of carbon so might as well take it off again and check it is ok.
Old Sep 26, 2015 | 03:51 PM
RichieST's Avatar
RichieST
Did that on mine too, tied it to a pallet and hit it with the steam cleaner at work, was amazed at how much crap came out of it!
Old Sep 29, 2015 | 10:31 AM
Farmer Giles's Avatar
Farmer Giles
Definatley do both together..
I had the main thermostat changed on mine as it never got up to full temperature. It did not resolve the issue so had the oil cooler one done a week later and all good again..
2p
ajamesc
Aug 17, 2015 03:31 PM
Escortdriver1
Aug 13, 2015 05:55 PM
RIB1122
Aug 12, 2015 08:51 PM
Old ford
Jul 31, 2015 06:50 AM
