co2 settings for cosworth stage 3?
Old Sep 18, 2015 | 07:20 AM
wheelwizardrefurbs's Avatar
wheelwizardrefurbs
Default co2 settings for cosworth stage 3?
would anybody have the co2 settings for cosworth stage 3? i have the use of the co2 machine just need to know the numbers.
my spec
bosch 803s dark green injectors
3 bar map sensor
31 actuator
T34/55 turbo
L6 ecu
motorsport developments evo chip. Thanks everyone.
Old Sep 18, 2015 | 10:14 AM
Loomer's Avatar
Loomer
Between 1.5% and 2.5% would be acceptable, but its far more important to check the AFR under full load to ensure safety, base CO has no real relevance to on load fuelling.
Old Sep 18, 2015 | 02:24 PM
brooksy898's Avatar
brooksy898
so the instruction you would get with lets say a Evo chip from Msd are no good. or are they basic guide lines.
Old Sep 18, 2015 | 02:39 PM
Loomer's Avatar
Loomer
The instructions will always state check under load.
SmudgerByName
52
Jul 28, 2016 06:14 PM
FlashRS
Aug 30, 2015 08:07 PM
Steve Escos
Aug 24, 2015 07:56 AM
JasonPD
21
Aug 20, 2015 07:36 PM
Aug 14, 2015 07:29 AM
