Maintenance For a Beginner
Old Sep 17, 2015 | 02:11 PM
Botts's Avatar
Botts
Default Maintenance For a Beginner
So i've had my Ford for a about a month Started driving home one night and when I got home I heard a hissing noise from under the bonnet when to check it and the engine coolant was bubbling waited till the morning and then enging coolant is above the Max marker could the enging coolant be overfilled and bubbling over how would I go about draining the resovoir and and re-filling or is it not as simple as that and will I have to take it to a garage?
Old Sep 17, 2015 | 05:48 PM
Caddyshack's Avatar
Caddyshack
I doubt over filling would make it boil. To drain a bit of fluid you can either Google the thep of car and find the bleed nipple and see if anything comes out with the engine cool and running. If not then you would need to loosen off a lower pipe and let a little drain out but not much.
I would then be looking for the source of the problem. These things can be a bit frustrating to find. Can you post up the make and model number including the engine size and type as it could be common.
If in doubt seek a pro
Old Sep 18, 2015 | 08:27 PM
matts1's Avatar
matts1
as above, get the model, year etc up so we know what you have.
Maybe an air lock somewhere, you could run it stood with the cap off till it is up to temp and give the pipes a good squeeze (hot so careful) and see if you shift the air. Also the rubber gromit inside the caps can kink and perish so make sure it is flat and good condition.
Old Sep 19, 2015 | 09:47 AM
martysmartie's Avatar
martysmartie
Could also be the pressure cap.
Martin
Old Sep 19, 2015 | 08:11 PM
andy.v's Avatar
andy.v
could also use a large syringe or turkey baster, to take some water out.
Old Sep 22, 2015 | 02:04 PM
Fast Guy's Avatar
Fast Guy
Was it running running hot at the time? IE was it overheating and the fan had come on?
Has the cooling system been touched recently?
If the cap's ok and it's been bled properly so no air locks you might be looking at something a bit more serious.
Make sure the water pump belt hasn't failed.
Thermostats can fail so they don't open, so might be worth checking.
The water pump may have failed (normally they have a tell tale leak below their location where you park)
Or possibly the head gasket failing and pressurising the cooling system.
Chas
Sep 21, 2015 08:57 PM
Bailes1992
Aug 16, 2015 07:14 PM
Old ford
Jul 31, 2015 06:50 AM
foreigneRS
Technical essay Archives
Jul 20, 2004 11:46 AM
foreigneRS
Jul 20, 2004 11:06 AM
