Indicator/Hazard Light Probs -Help!!
Old Sep 11, 2015 | 02:08 PM
Cossikev's Avatar
Cossikev
Default Indicator/Hazard Light Probs -Help!!
I'm in need of some advice. If I put my hazards on (which don't work) my indicators stop working. Is this down to the switch putting them out of action? The indicators work fine but I can't get the hazards to work, any suggestions would be much appreciated.
Old Sep 11, 2015 | 05:16 PM
cossie330's Avatar
cossie330
Without seeing or testing sounds like you need a new indicator stalk
Old Sep 11, 2015 | 05:30 PM
Cossikev's Avatar
Cossikev
Thank you for your reply. However I have changed the stalk today, but no success. Any Ideas on what else it could be. (maybe a relay). Only been an rsoc 2months and I'm not very computer literate. Had the 4X4 for 5months and am slowly going through the issues on the car.
Old Sep 11, 2015 | 07:39 PM
dojj's Avatar
dojj
Resident Wrestling Legend
There is a flasher relay behind the instrument panel clipped between the heater vent pipe and the dash metal support bracket
If the stalk hasn't fixed it it'll most likely be that one
But also the fusebox can cause these issues too as that's what it turned out to be on mine
Old Sep 11, 2015 | 10:14 PM
rdvil's Avatar
rdvil
Hazards have their own relay and fuse, don't remember where but you can find the haynes manual online with a quick googling. Found this when I noticed hazards work even when the indicator fuse is blown.
Old Sep 12, 2015 | 04:14 PM
Cossikev's Avatar
Cossikev
Default Hazard lights
Thanks for that info any idier wear I can get a relay from to try as parts I have been looking for might be easeir to find the jewels off tuton carmoon
Old Sep 13, 2015 | 02:00 PM
dojj's Avatar
dojj
The flasher relay is much taller than a standard relay but I'm not sure if they were the same on any other car
gcfcos
59
Oct 6, 2015 05:04 PM
Steve Escos
Oct 1, 2015 06:57 AM
stevecfrst1
Sep 30, 2015 05:18 AM
Sep 28, 2015 10:05 AM
