setting up MK rear beam
I'm in the same boat, i rang one spot and they said they set up using mirrors and string - i thought yes maybe it used to work fine but i don't fancy a fully adjustable beam done that way.
Then it turns out a garage around the corner can sort it but the guy is away rallying for a month
You'd be surprised at how many people still prefer to set it up that way, drawing a centreline down the car etc.
But yes id take it to somewhere with 4 wheel laser alignment, but it's bloody expensive if you adjust everything!
Mark
The bloke at RSR engineering used to run the le mans racers for AFN Porsche and then Won the Porsche Cup with Paul Edwards many times....he always used to string my car and all the GT3's and 911 RSR race cars.
Oct 9, 2015 07:38 PM
155lee
Sep 14, 2015 07:37 PM
