High Idle .......... (FAO MSD?)
Old Sep 5, 2015 | 02:55 PM
RSmark84's Avatar
RSmark84
Unhappy High Idle .......... (FAO MSD?)
My EFI CVH turbo engine idles high, Its chipped by MSD. I thought it was the ISCV, So I cleaned it out and re-fit it. It still happened, So I unplugged the coupler from the unit itself, It then decided to idle correctly.
Next step was to remove the Chip from the ECU, The Engine then Idled correctly, So I re-fit the Chip and it idled back up to 2500-3000RPM. Its off the road until Spring next year now. Any EFi gurus on here that can shed some light?
Ta in advance.
Old Sep 5, 2015 | 04:02 PM
gcfcos's Avatar
gcfcos
Default High Idle .......... (FAO MSD?)
I've got the opposite problem on my saph. Had a stage 1 pts chip and ran fine. Fitted a stage 3
Msd chip and it hunts on idle. re
Fitted the pts chip and runs mint even on the greens and 3 bar map sensor. Can't afford to get it to Blackpool to have it mapped as thought like the pts chip u could set it up yourself :-(
Old Sep 5, 2015 | 04:29 PM
Ridgey's Avatar
Ridgey
If it idles fine with ISCV disconnected , then surely it is this at fault ???
Old Sep 5, 2015 | 05:47 PM
RSmark84's Avatar
RSmark84
Not really, because it idles fine connected with the chip removed. Its strange the car is fine with the chip removed, its only strange the car was fine as it was before I stored the car for 2 months on trickle charge. first drive afterwards, it idles fine.
Its also been stored with the battery disconnected for 24 hours too.
Old Sep 5, 2015 | 05:48 PM
RSmark84's Avatar
RSmark84
at the tag, dont go to MSD. The chip was fitted before i bought the car, and has been set up with it fitted
Old Sep 5, 2015 | 05:55 PM
martysmartie's Avatar
martysmartie
I assume this is Cosworth managed, if so check the TPS calibration.
Gcfcos, you should always get the fuelling checked, I suspect your CO is out.
Martin
Old Sep 5, 2015 | 05:59 PM
RSmark84's Avatar
RSmark84
Not cosworth managed just normal OFAB/OFAC EFi CVH H plate FRST.
Old Sep 5, 2015 | 07:23 PM
gcfcos's Avatar
gcfcos
Martin
Had it on the gas analyser at work and it's 1.5% co, sorry wrote overfueling by mistake it's my mates the other week that was overfueling lol :-( going mad in my old age!!
Old Sep 5, 2015 | 07:35 PM
carl n 1977's Avatar
carl n 1977
I would try 2.5 or 3 % on co mate just to see if that helps and gets rid of the hunting on idle
Old Sep 5, 2015 | 08:48 PM
RSmark84's Avatar
RSmark84
Got a replacement ISCV coming. Only cost £20.60 so worth a try.
Old Sep 5, 2015 | 10:02 PM
smiley's Avatar
smiley
I have an msd stg 3 cosworth that hunts also cheers will try that
Old Sep 6, 2015 | 09:48 AM
RSmark84's Avatar
RSmark84
Threads gone a proper u turn.
Anyone?
Old Sep 6, 2015 | 09:50 AM
Karl @ FPT's Avatar
Karl @ FPT
Always a pleasure!
High idle could also be an air leak, certainly as you say it idles fine with the ICV unplugged (which it shouldn't, where is the air coming from to maintain the idle speed?), always good to check the simple things first mate as it may be a coincidence that it idles correctly without the chip.
Old Sep 6, 2015 | 10:22 AM
carlo's Avatar
carlo
My Efi cab 195 chip is the exact same there is loads of threads about it but I can't get to the bottom of it
Old Sep 6, 2015 | 02:10 PM
RSmark84's Avatar
RSmark84
Thats the 2nd person to mention air leak. Will have to remove boost hoses and vacuum pipes and check for holes. Its very strange for it to happen while being stored and not touched.
Carlo I replied on RSOC about yours, Is your chip MSD too?
Old Sep 6, 2015 | 06:54 PM
gcfcos's Avatar
gcfcos
I was told to unplug the idle control valve and re set the base idle and then plug it back in and let idle settle and then adjust the co. The bloody idle screws seized typical 4x4 saph problem. Strange how it idles fine on pts chip
Old Sep 12, 2015 | 04:32 PM
RSmark84's Avatar
RSmark84
Cleaned and fit the replacement ISCV, still the same. Let the engine warm up and still the same. unplugged the ISCV and then refit. Still the same. Removed the Chip and this time the idle still was high.
Each time I gave the engine a good rev and the idle would drop slowly.
So since last time, I reconnected the battery after having it disconnected in that time. Each trial was exact procedure as my first post.
Old Sep 12, 2015 | 06:54 PM
costina's Avatar
costina
Live long and prosper!!
Mark. Drive it the ecu needs to relearn idle and all sorts of other stuff. Esp after the battery is disconnected.
If it still high then look for a air leak esp where the vac pipes go into the inlet and breather.
Paul
Old Sep 13, 2015 | 12:33 AM
RSmark84's Avatar
RSmark84
I tried that a couple of months ago, remove the ISCV clean it and re-connect battery the day after. No change, I think i'll change all vacuum pipes including to the boost gauge(that one is plastic).
I do miss driving an RS and am tempted to re- tax and insure one, and the Fiesta may be it.
I did wonder if the TPS would cause the revs to drop slowly after revving it.
Old Sep 13, 2015 | 01:29 PM
costina's Avatar
costina
Anything is possible Mark. My efi cab idles a bit high too.
boeb
Jan 9, 2020 05:11 AM
fordrallycar
Sep 30, 2015 07:57 PM
